Cooler thermostat
Old 06-08-2005, 12:01 AM
Jglisson
Jglisson's Avatar
Default Cooler thermostat
Anyone run a cooler thermostat with good results? I am not sure what the stock t-stat is...I would guess 195 degrees. Anyone tried a 180 or lower?
Jglisson is offline
Old 06-08-2005, 01:46 AM
LIVIN_LEGEND
LIVIN_LEGEND's Avatar
Default RE: Cooler thermostat
got the 180 Degree....... works good, easy install, cheap
install video (i learn as i go)
LIVIN_LEGEND is offline
Old 06-08-2005, 03:15 AM
DILO2001GT
I ♥ Acer
DILO2001GT's Avatar
i just ordered the 160 thermostatfrom SLP. it comes on there power pac for the 99-04 GT's so i chose that one. they also sell a 180 degree one like you guys are talking about.
DILO2001GT is offline
Old 06-08-2005, 07:49 AM
nightmare
nightmare's Avatar
i also have the SLP 160 thermo and i works really well driving temps stays down low
nightmare is offline
Old 06-08-2005, 08:46 AM
Jglisson
Jglisson's Avatar
How much for the 180 or the 160? 160 seems a bit cool, suprised it doesn't bring on a check engine light. I would rather run cooler though, especially down here in Florida. I haven't seen any on Ebay...
Jglisson is offline
Old 06-08-2005, 01:06 PM
code3GT
Mustang Nazi
code3GT's Avatar
Also running an SLP 160 degree thermo.
code3GT is offline
Old 06-08-2005, 03:06 PM
Deannostang
Deannostang's Avatar
I use a Stant 180 degree myself. Same basic thermostat Steeda sells. Steeda recommends the 180 and NOT the 160 as they claim the 160 makes your engine run too cold for proper computer control. You can go to www.steeda.com and do a search on "thermostat" and you will see a brief explanation. Better yet, call them and you'll get a whole earful of why the 180 is a good choice.
One other good choice most Mustang owners are not aware of is the Ford Racing thermostat. They offer a special high-flow stat that bypasses the water under high rpm's and helps reduce cooling system pressure that can cause damage to your gaskets and plastic manifold....the infamous "cracked" maniforld. Check it out at:
http://www.fordracingparts.com/parts...tKeyField=3410
Deannostang is offline
Old 06-08-2005, 03:37 PM
DILO2001GT
I ♥ Acer
DILO2001GT's Avatar
ORIGINAL: Jglisson
its 10 bucks at www.slponline.com
Old 06-08-2005, 03:56 PM
TheBob98GT
TheBob98GT's Avatar
newbie question here : where is the thermostat located?
TheBob98GT is offline
Old 06-08-2005, 04:34 PM
LIVIN_LEGEND
top of th radiator hose ----- http://michael.web.aplus.net/sitebui.../180degree.wmv
Quick Reply: Cooler thermostat
