Penzoil killed my pony!!!
Hey guys not literally yet, but I have been using penzoil in my 01 gt since 30k and I have been reading and found out that penzoil is wax based and i have heard alot of bad things about wax build up, and I heard that if i switch to a synthtic oil that i will have chunks of wax build up through out the motor how can i switch over to a better oil safely right now i have been using Penzoil conventional 5w-20, i want to get away from it so my motor will be ready to handle a supercharger safelythis summer! ps. the car has 70k miles on it now
Do not put STP oil treatment in your engine, that stuff is like motor honey. Before you get to worried stick you finger in the oil filler cap on the valve cover and see if there is any sludge. If not then you are ok, I suspect that if you changed the oil on a rugular basis then you will be ok.
