Jacking the car without bending sheet metal?
Old 02-22-2009, 02:34 PM
04STANG3.9
04STANG3.9's Avatar
Default Jacking the car without bending sheet metal?
Just wondering...what r some techniques u guys use to jack up the jar without bending the sheet metal
btw i use a floor jack and the point is too big to use the designated jack point for the little jack that comes with the car
04STANG3.9 is offline
Old 02-22-2009, 02:38 PM
mustangman281
Banned
mustangman281's Avatar
K member and axle.
mustangman281 is offline
cliffyk
TECH SAVANT
cliffyk's Avatar
Here are the jacking points from the 2003 shop manual...
cliffyk is offline
Old 02-22-2009, 03:01 PM
04STANG3.9
04STANG3.9's Avatar
thanks....helps a lot
Old 02-22-2009, 03:09 PM
StriderTacticaL
StriderTacticaL's Avatar
I and a lot of people I know just jack the car up from the subframe connectors....at the ends of each one
StriderTacticaL is offline
Old 02-22-2009, 04:32 PM
98GTstang
98GTstang's Avatar
lets see..It depends on what im doing to the car. Sometimes i jack it up by the pinch welds, which tend to bend a little bit or the frame which does not bend. And i jack the back up by the diff.
98GTstang is offline
Old 02-22-2009, 05:40 PM
ezking
ezking's Avatar
front i use the k member
rear i use the diff
i try to avoid using jack stands on the rocker panels as well, the can dmg the moldings or ur break lines.
anything that supports the weight of the car as its job, is a safe bet.
ezking is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
inyadreems
08-21-2015 09:10 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Jacking the car without bending sheet metal?
