3650 trans problem 3rd and forth
Old 02-26-2009, 11:35 PM
Alexs03yellowgt
Alexs03yellowgt's Avatar
Default 3650 trans problem 3rd and forth
I just bought a 03 gt 5spd from a guy and it has transmission problems its missing 3rd and 4th gear its like theres nothing there when you go to put it in those gears 1st 2nd and 5th are good and the cars clutch and all seems fine what do you think it could be? car has 100k on it the guy cut me a deal.
Alexs03yellowgt is offline
Old 02-27-2009, 07:29 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
I have not seen a T-3650 trans appart, but my Vega trans lost first gear when I dumped the clutch back in th' day. I pulled it apart and the gear was in two pieces and laying on the bottom of the pan. I just purchased a new trans and with 100K miles, you will probably be best served to do the same.
Take it to your local mechanic familiar with your trans and see if it is worth rebuilding.
HTH... not hurts
Jazzer
Jazzer The Cat is offline
Old 02-27-2009, 12:26 PM
jivepepper
jivepepper's Avatar
Either the shift fork, and or the synchronizers are out.
jivepepper is offline
Old 02-27-2009, 10:27 PM
Alexs03yellowgt
thanks for the answers do you know where i can get the shift fork and possibly the synchronizers online .. or who i can order them from thanks
Old 02-28-2009, 12:28 AM
StriderTacticaL
StriderTacticaL's Avatar
Most likely it won't be worth rebuilding. If you got your car for a really good deal because of that problem, just spend like a grand and get a rebuilt 3650 and you will have a perfectly working car
StriderTacticaL is offline
Old 04-30-2009, 05:36 PM
AmericanPowertrain
Former Sponsor
AmericanPowertrain's Avatar
Default 3650 Problems solved
You probably have a bent or broken shift fork. This is very common and can be fixed with either a stock rebuild, or better yet, an upgrade. We can build your transmission to take more abuse, or simply provide parts and tech to get you back on the road. Let me know if I can help. Gray@AP
AmericanPowertrain is offline
mtgldr
02-03-2024 09:00 PM
97SN95GT
09-13-2015 09:45 PM
Pyrate Dave
09-10-2015 07:30 PM
Blk Vert
09-09-2015 12:16 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: 3650 trans problem 3rd and forth
