180 thermostat
Old 03-05-2009, 12:23 PM
98SN95
98SN95's Avatar
Default 180 thermostat
can i run a 180 thermostat without any problems?
98SN95 is offline
Old 03-05-2009, 12:43 PM
lizzyfan
Underboss
lizzyfan's Avatar
Sure can!
lizzyfan is offline
Old 03-05-2009, 01:19 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
A 180° T-stat will lower combustion chamber temps and allow more aggressive timing settings, it will also slightly increase emissions if you live in a place that tests such things...
cliffyk is offline
Old 03-05-2009, 02:59 PM
stangalator
stangalator's Avatar
good for high CR too
stangalator is offline
Old 03-05-2009, 04:03 PM
jeremy175
jeremy175's Avatar
Can you benefit much from a lower degree thermostat? I've already got my timing bumped up 2 degrees and seems to do really good there.
jeremy175 is offline
Old 03-05-2009, 04:11 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
I ran a 180 on my car for years. Never had a problem here, and (as stated above) after my PI swap my shop was able to have more play in timing it.
96GT226410 is offline
Old 03-05-2009, 04:12 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
As previously stated, "A 180° T-stat will lower combustion chamber temps and allow more aggressive timing settings, it will also slightly increase emissions if you live in a place that tests such things..."
I am running +4.5° over stock global advance, and +2.0° in the Spark Borderline table settings at the higher loads and rpms--this means that as WOT I am +6.5° over the stock tune limits--this is all with 93 octane fuel of course...
cliffyk is offline
Old 03-06-2009, 10:55 AM
98SN95
98SN95's Avatar
well my other post i was asking about this valvetrain noise im hearing, it does it at all rpms and loads, i thought it may have been pinging but it kinda sounds like lifter slapping, but really lite, i think it may be normal but im not sure, still dont have a tune for the swap but the car runs stronger than before, if the timing is causing this very lite pinging noise, assuming that it is ping, lower temp stat should help or fix it i think, any help from those who have done the swap on the 98 gt i will appreciate. i also have the cobra oil pump.
98SN95 is offline
Old 03-12-2009, 03:04 PM
98SN95
98SN95's Avatar
BUMP.
98SN95 is offline
Old 03-12-2009, 06:00 PM
stangalator
i will being doing my swap soonish (after spring break), but you should PM Pohatu18, he just recently swapped his, he might be able to help
Nick Oliver
10-17-2018 04:22 AM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
67LimeCoupe
11-25-2015 08:55 PM
MusicCity615
09-12-2015 07:05 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: 180 thermostat
