throttle body install...gone bad
i installed my 75 mm accufab throttle body today and here are a list of the problems im having thus after the install:
1. hanging rpms
2. idles 400 more than before
3. makes a whistling sound with partial throttle (need help with this especially havent seen much on something like this)
WTF DO I DO?????
thanks guys!!
1. hanging rpms
WTF DO I DO?????
thanks guys!!
theres a hanging rpm fix in the stickies, read the stickies, the whistle is normally, they all do that with aftermarket ones, but i dont know why the idle would be so much higher, unless the computer wasnt reset.
You didn't say what year your car was, but the higher idle can be a couple things depending on the year of the car.
If it's a 96-97, I think the TPS sensors could be adjusted in those years, not sure about the 98.
I know the 2000+ zero out the TPS sensor every startup, so if it's a 2000+, you may need to reset the computer, and let it relearn due to the additional airflow
Did you get a CEL? I broke my TPS when I changed my TB and did the same as yours, idled high and hanging rpms. All aftermarket TBs tend to whistle my accufab TB only does it when 10%-15% or so on the throttle.
