Replacement Keyless Remote
Old 03-20-2009, 02:28 PM
klynam
klynam's Avatar
Default Replacement Keyless Remote
I looked on the forum and online but can't find this answer...
When we bought our daughter's 96-GT, we received one key and one keyless entry remote. After some research, I've identified this as a Code Alarm (brand) 2-button unit, FCC ID: GOH-MM6-101890.
I've found a couple of used "Ford" brand replacements on eBay in the $20-$30, everything else online seems to be in the $50 range.
Do I have to buy this exact remote, or can I get one of the other (generic) multi-button remotes and use the 8-cycle on/off procedure to program it?
Anyone ever done this?
klynam is offline
Old 03-20-2009, 08:37 PM
BigBadRick
BigBadRick's Avatar
You can buy a new Keyless Entry system for right around the same price. It is easy to install. Maybe 6 or 7 wires total.
BigBadRick is offline
Old 03-20-2009, 09:15 PM
mustang_pa
mustang_pa's Avatar
I had the same problem as you. I bought a new remote off ebay for $25 two years ago and did the little remote programming thing. It has worked great since the day i bought it.
mustang_pa is offline
Old 03-20-2009, 09:20 PM
sstang
sstang's Avatar
Mmm I'm in need of a remote too. Mine was smashed a couple months ago. Anyone have a link on the programming procedure?
sstang is offline
Old 07-26-2009, 12:50 AM
migu87
migu87's Avatar
Its simple , I just did it today with a remote i brought off ebay for 15 bucks . You just open ur trunk take out the front panel and then the driver side paneling theres going to be a black box with two sides the front is empty but the back is where the keyless remote module is located. Theres a grey connector with nothing attached to it in the bottom right front . you just have to put the key in the on position without turning the engine on , and go to the trunk and put a screwdriver inside the grey connect making sure it touches the two pins which will makes the locks cycle and then you push a button on the remote. It should work then turn the key in the off position .
migu87 is offline
Old 07-26-2009, 08:32 AM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
PROGRAMMING PROCEDURE
NOTE: The remote keyless entry module erases all previous keyless entry remote transmitters from memory when the keyless entry remote transmitters are programmed or reprogrammed. The remote keyless entry module can store up to four keyless entry remote transmitters in memory. All keyless entry remote transmitters must be programmed (reprogrammed) at the same time.
To program (or reprogram) keyless entry remote transmitter into the remote keyless entry module, perform the following steps:
1. Turn ignition switch to RUN or ACC position and momentarily short the two terminals of the Program Connector (two-pin connector next to the remote keyless entry module. Remove LH luggage compartment trim panel to reach the connector). Both doors should lock and then unlock. Remove shorting pin.
2. Press any button on keyless entry remote transmitter. All front doors should lock and then unlock to verify that keyless entry remote transmitter has been programmed.
3. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter). If door locks still fail to respond, go to Pinpoint Test A.
4. Repeat Step 2 to program additional keyless entry remote transmitters into the remote keyless entry module (up to a maximum of four keyless entry remote transmitters).
5. Turn ignition switch OFF. Both doors should lock and then unlock.
6. Check operation.
ChalknCover is offline
Old 07-26-2009, 11:59 AM
jwog666
jwog666's Avatar
6. Check operation.
thats the procedure for the newer vehicles, the op's is a 96 and requires the procedure that migu87 posted.
jwog666 is offline
Old 08-11-2009, 06:37 AM
catr_
catr_'s Avatar
there you find the procedure for 96 http://www.carandtruckremotes.com/pr...--mustang.html
catr_ is offline
5.0muscle
01-11-2016 01:17 PM
9550
10-26-2015 05:01 PM
67STANGX2
09-24-2015 12:29 PM
MusicCity615
09-12-2015 07:05 AM
Art161
09-09-2015 10:33 AM
Quick Reply: Replacement Keyless Remote
