need Tq specs for tranny and drive shaft bolts
Old 03-25-2009, 12:24 PM
Jskeezy84
Jskeezy84's Avatar
Default need Tq specs for tranny and drive shaft bolts
Im getting ready to do a clutch job on my car and i need some info. I bought a haynes manual and its doesnt give a specific tq spec for anything, it just gives huge gaps like 20-45ftlbs. I dont feel confortable just picking a number.
I need the tq numbers for:
bellhousing to engine
tranny to bellhousing
drive shaft to rearend
flywheel
pressure plate
Jskeezy84 is offline
Old 03-25-2009, 12:34 PM
Xemeth
Xemeth's Avatar
The only torque spec you'll need: tight.
Seriously, following torque specs really isn't that important unless it's something like head bolts, or the spark plugs in the case of the 4 thread holes on these cars. The only thing you should do it use a cross pattern when installing the flywheel and pressure plate, similar to tightening lug nuts. You don't need to follow a specific torque spec for anything that you're doing here. As long as everything is tight you're good.
Xemeth is offline
Old 03-25-2009, 12:47 PM
CAMDUP
CAMDUP's Avatar
u might wanna torque flywheel & pressure plate........ and u wont be removing bellhousing from tranny
http://www.badazzponys.com/html/must...que_specs.html
CAMDUP is offline
Old 03-25-2009, 02:53 PM
Jskeezy84
Jskeezy84's Avatar
scratch that. I found a buddy to do it at his shop for 200. More than i wanted to spend but it sure beats 660 at ford. Thanks for the replies though!
ShaneB26154
35
03-04-2021 04:05 AM
Gary Ugarek
63
12-11-2015 02:01 PM
Jskeezy84
09-08-2015 01:40 AM
kevans79@yahoo.com
08-18-2015 09:01 PM
Boostaddict
Lethal Performance
08-13-2015 01:57 PM
Quick Reply: need Tq specs for tranny and drive shaft bolts
