Door panel removal.. How?
Old 03-30-2009, 08:32 PM
LynnBob Mustang
LynnBob Mustang's Avatar
Default Door panel removal.. How?
How do I remove the interior door panel on a '99 GT?
I screwed up my damn window tint because of the felt strip and I want to take it off so when the replacement arrives so I can try again.
Thanks,
Lynn
LynnBob Mustang is offline
Old 03-30-2009, 09:07 PM
Brute03
Brute03's Avatar
you have to remove the trim piece that holds the switches; it snaps in and out but be careful, the little tabs break easily.
behind the trim you should see a couple screws, remove those. also, there's a plastic push pin down by the speaker on the outside edge that you have to remove. you might want to pull the tweeter cover off too.
now grasp the panel at the bottom and sort of pull down then out slighty. after the bottom is free, you should be able to lift it up and off
Brute03 is offline
Old 03-30-2009, 09:10 PM
HateWhatOwnsYou
HateWhatOwnsYou's Avatar
that felt weather stripping does not come off with the panel, i was going to do the same thing but gave up once i got the panel off. it looked like a pita to get off
HateWhatOwnsYou is offline
Old 03-31-2009, 06:31 AM
LynnBob Mustang
That's a bummer!!
Thanks for the help.
Lynn
Old 03-31-2009, 07:23 AM
TheDarkKnight
TheDarkKnight's Avatar
Default Weather strip
Are you talking about the inner or outer felt wipe. The inner one is attached to the door panel on my 02GT. I just had it off and replaced the outer one because it was scratching the glass on the outside of the car!? The outer one is attached to the door (1 rivet) and is about $35 or so from Ford. I would have to look at a door panel again to see if the inner was replaceable and how it was attached, but I would think both would be replaceable, not just the outer. Who knows, Ford may want you to buy the entire panel though!!!
TheDarkKnight is offline
Old 03-31-2009, 07:25 AM
jrherald420
jrherald420's Avatar
just take your time...its easy.
jrherald420 is offline
Old 04-03-2009, 08:01 AM
TheDarkKnight
Thanks,
Lynn
Lynn,
wasn't sure if you had already got your door panel off or not, but I stumbled across this helpful little link and thought I'd pass it along...
How to remove the door panel on a 1999 - 2004 Ford Mustang
Old 04-03-2009, 08:01 PM
LynnBob Mustang
Cool, thanks!!
Lynn
Old 06-20-2009, 02:03 PM
StripeyGT
StripeyGT's Avatar
Thumbs up
Originally Posted by TheDarkKnight
Lynn,
Hey, thanks for posting this link. It was very helpful in getting my panel safely off and on. This forum rocks!
StripeyGT is offline
jerrytubes
10-23-2015 12:11 PM
b8checker
10-08-2015 12:55 PM
jrrhd73must
10-02-2015 09:17 PM
b8checker
09-30-2015 07:11 AM
Quick Reply: Door panel removal.. How?
