Got a terrible miss at idle and no power
Old 04-19-2009, 11:13 PM
jeff37110
jeff37110's Avatar
Default Got a terrible miss at idle and no power
Basically, I was going to race one of my buddys dropped it down a gear and lost all power all at once. Not sure if I broke something or have a bent valve. I have put new plugs,coils,fuel pump,regulator,checked all injectors. Just wondering if anyone has any ideas of what it could be?
jeff37110 is offline
Old 04-19-2009, 11:16 PM
0949er
0949er's Avatar
we need more details. can you crank the engine at all, etc.
and when you say dropped it down a gear, do you mean that you were 4+ rpms in 4th and went into third, or what?
0949er is offline
Old 04-19-2009, 11:18 PM
jeff37110
jeff37110's Avatar
It starts and runs but it misses really bad... I was in third gear about 2500 rpm went to second.. It still runs ok but it acts like a dropped a cylinder or part of my engine is not working.
Old 04-19-2009, 11:20 PM
0949er
0949er's Avatar
so you have replaced all your plugs/coil packs/etc and found those all work 100%?
if so, have you checked your compression? How does your oil look?
0949er is offline
Old 04-19-2009, 11:21 PM
JJ03MustangGT
JJ03MustangGT's Avatar
how many miles are on the car?
JJ03MustangGT is offline
Old 04-19-2009, 11:43 PM
jeff37110
jeff37110's Avatar
136,000 miles. The oil is clean, doesnt have but about 200 miles on the oil. The plugs are burning correct and wires are also. We run a snap-on scanner to check voltage and burn times for the plugs. Havent tried a compression check yet. Should I go in the compression check direction? If so what kind of numbers should I look for in the cylinders?
Old 04-20-2009, 01:27 PM
5.0 85 GT
5.0 85 GT's Avatar
the compression numbers for my 02 were around 120...the two missing cylinders i had were pushing 80..then after i replaced the coil packs they were all hovering around 120...
5.0 85 GT is offline
Old 04-20-2009, 03:51 PM
Andy13186
Andy13186's Avatar
did you rev match? it dosnt seem like shifting from 3rd at 2500 to 2nd would be too violent on anything...
GL
Andy13186 is offline
Old 04-20-2009, 05:36 PM
jeff37110
jeff37110's Avatar
Basically just dropped a gear and punched it, and it all at once lost all power. It has missed since then.
Old 04-20-2009, 08:49 PM
jeff37110
jeff37110's Avatar
How did you preform your compression check with all plugs out or one at a time? Also did you warm the motor up first?
Quick Reply: Got a terrible miss at idle and no power
