One Windsor, One Romeo head
#21
The cam caps and rides are bored from the factory. No two cams caps are the same. If you mix up the cam caps then the head is useless unless you want to pay a machine shop to rebore it. Clearance top and bottom isn't the problem its the sides where the caps meet the rides. If they are off just a little they will gouge you cam and the metal shavings will sieze the cam and probably screw up alot more like oil pump, crank/rod bearings, cylinder walls and other cam. Do it right and use the caps that came with the head. It doesn't matter what cam you put in (windsor or romeo or aftermarket) as long as you use the caps for that head.
So all I have to do is use the numbered Windsor journal caps I took off and there shouldn't be any problems. I measured both cams with my mic and everything is the same. But I want to use the matching Romeo cam to be safe.
Thanks for the help!
#23
#25
I am having the same exact problem, the plug blew out in my 01 gt on the driver side and it was on clyinder #6 and we had tried to fix it by using the MAC plug repair kit and it was shuttering under a load and it didn't fix this problem when we "tried" to repair it and now we went to just getting a new head so and yea like my luck ended up with a windsor head...but my question is, if we replace the head do you guys think it will fix the shuttering problem that it first had? I bought this car like this and the guy had lied to me and said it was only a coil and it wasn't we replaced those and even checked the fuel injectors nothing. Please help!
#26
You can use caps from another head if you line bore them. The caps on my SVO's are webbed and one of them was broken (dumb *** dropped it). I had to replace the whole cap and have it line bored. As long has its a problem with the clearance being too small you can have it machined.
bradleyb
11-27-2015 07:50 PM
