97 gt- PI swap- Head Gasket Size Choice?
Chris, what compression are you running? After reviewing hci combo's, im going to try KB 6psi on stock NPI sb w/ Pi swap. The numbers should still be decent with a tune..and safe. I called KB on this one and they said it would be fine, just dont get crazy or greedy, no problem.
I was wondering what size head gasket I needed to bring the compression ratio on a 97 gt (with PI heads) back to its original 9:1?
I am going to do a PI swap on my 97 gt with 148,000 miles. I have had this car since I was 15 and I plan on keeping it for as long as I can ( I take very good care of her). My dream is to have a sick turbo setup when I am all done with everything, but I don't plan on spending much cash until I finish my Engineering Degree and get a real job. I want to plan for the future and keep a lower compression ratio for a turbo setup, but I am wondering if I am looking to far into the future. If I were to use thicker gaskets to low the CR, I would probably do the work right the first time and get a set of Cometic gaskets that I hear are great on turbo setups. This could be a few hundred dollars more and it might be a waste if I am going to wait a couple years for any forced induction. I am also concerned about the amount of miles on the rotating assembly and block. Should I use the stock size head gaskets that would make it cheaper but would give me a 10:1 compression ratio? My thought behind this was I could wait till the bottom end busts and then build a bullet proof setup for a turbo.
I use this car for allot of highway miles, dose a higher compression dramatically affect my gas millage? What do you Think?
11-10-2015 11:39 AM
10-05-2015 06:07 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
09-03-2015 07:14 PM
