Helpful Directions (Shift Kit)
Old 04-28-2009, 11:33 AM
sonicx
speed'n
sonicx's Avatar
Default Helpful Directions (Shift Kit)
Im first curious to know what excatly a shift kit does/ for? Then does anybody know what the best shift kit for a 2004 GT? I read somewhere that its not good for 2000+ mustangs but i more curious than anything.
sonicx is offline
Old 04-28-2009, 03:26 PM
grogan
grogan's Avatar
a shift kit is for at the track. it lets u shift the car at whatever rpm u want when u leave it in 1,2 and d. stock trans's dont shift as quick. ( if u shift at 5500 a normal shift would go at 5800 verses the shift kit that would shift at 5500)
grogan is offline
Old 04-28-2009, 04:10 PM
dimebag
dimebag's Avatar
ok no.
a shift kit makes your shifts firmer... a manual valve body allows you to shift... big difference. and fwiw, a shift kit is not just for the track
dimebag is offline
Old 04-28-2009, 04:15 PM
grogan
grogan's Avatar
i know its not just for the track. i just gave an easy answer.
i dont have one in my stang, but i have one in my 80 malibu and all i did is decribed what it does in my malibu
grogan is offline
Old 04-28-2009, 05:42 PM
Hangwire
Hangwire's Avatar
Originally Posted by dimebag
ok no.
Right.....it pretty much just ups your line pressure doesn't it? When you refer to a "manual valve body" do you mean a J-mod? From my understanding a J-mod ports and re-routes your valve body so more fluid can flow....wrong or right?
Hangwire is offline
Old 04-28-2009, 05:55 PM
isjoining
isjoining's Avatar
a j-mod isn't a manual valve body, does the same thing a shift kit does.
isjoining is offline
Old 04-28-2009, 06:02 PM
Hangwire
Hangwire's Avatar
Theres a major terminality issue with this mod.....seen it called about four different things....most often a "J-Mod."
Hangwire is offline
Old 04-28-2009, 07:33 PM
isjoining
isjoining's Avatar
a j-mod allows more fluid in the valve body by increasing the size of the holes in the separator plate......basically what a shift kit does. a manual valve body makes an auto fully manual control and holds the gear its set to.
Old 04-29-2009, 02:49 AM
sonicx
speed'n
sonicx's Avatar
alright thanks... so prob sthang un needed for a street car.
sonicx is offline
Old 04-29-2009, 10:02 AM
isjoining
isjoining's Avatar
uh what?
a shift kit is fine for a street car...
Quick Reply: Helpful Directions (Shift Kit)
