Oil port on back of heads leaking? HELP PLZ
Hey guys so rebuilt my engine and while i am building oil pressure i had oil start to leak from the back side of my driver side head!? I had shipped my heads to MMR to get ported and polished so i didnt touch the heads really.. just took them off and put them back on the head. The oil is coming from a bolt hole on the back side (check picture) does anyone know what goes here? is it just a bolt, or what? thanks for any help guys
Sorry the pictures are kinda ****ty very hard to get back there ha :P
There is a hole that is supposed to be plugged on the driverside head. It;s an allen key plug. Take it out and apply new thread sealer to it and put it back in.
If its pouring out and there is no plug in there then you put the heads on the wrong side. You will have to pull the front cover off and take the plug out ot the front of the passenger side head and install it in the back of the driverside head.
x2 ... pull the cover and see if the plug is in the other head at the front of the motor. If it is, you need to remove it and put it in the back of the drivers side head.
i never new that??? hmmm.... good thing i havnt put the heads on yet.
so if i understand this correctly. the passanger side is able to run with out this allen screw and the driverside has to have it??
wow i never knew that?! Doesnt the cam only go on one way? wow ha im floored by this haha (little drunk at the moment) alright well i guess ill take off the timing cover and check to see if that oil plug thing is on the passenger side head in front
i have a 99 are you guys sure i can put them on backwards ha.. i swear there was a back and front haha.. i feel like a idiot for doing that! cause the cam cap that has 3 bolts was towards the front of the cam and thats how i put it back on... maybe MMR just put the por on the wrong side! hmm.. i gotta stop drinking hahaha
