Break lights, flashers and turn signals not working. Any ideas?
I still think its a multifunction switch BUT WITH OUT LOOKING AT IT IM NOT 100% SURE also they are easy to put in also take the 3 or 4 screws out of the plastic cover around the steering column take the tilt adjuster off remove the key cylinder (turn the switch to the run position and stick a small screw driver in the extra hole under the key and push it in the detent ball and pull the cylinder out.) Then remove the cover and remove the 2 bolts and the 2 connectors on the multifunction switch. as for the price im not sure
