swapped k member now hearing noises
upr chromoly kit with 14 inch 175 springs
every bolt is tightened. but i still hear the banging. sounds like the shocks are gonna come through the shock towers and through my hood.
any thoughts?
any thoughts?
the k member is sitting flush and the headers have about an 1 of space around them. lakewood drag struts last how many miles? its the 70/30s i have about 15k miles on them. could that be it.
struts that have failed will make a similar sound to what you describe. Did you convert to coilovers with the k? Try the bounce test and see if the front of your car oscillates more than one time up and one time down when you jump on it. Check to make sure the nut on top of your struts isn't too high. If it is it will allow your strut freedom to move when compressing/decompressing. Best way to check this is to rock the front of the car with the hood up and watch the strut shaft where the nut ties it down.
