did my untuned Supercharger just blow my motor?
Old 05-12-2009, 07:12 PM
  #61
mustangman281
Banned
mustangman281's Avatar
If you broke a ring land you would have alot of smoke. TR6's are very weak plugs which make them good because they will break from detonation before the engine will. If you had put in motorcraft plugs with the same heat range then you would have destroyed your engine.
mustangman281 is offline
Old 05-12-2009, 07:34 PM
  #62
yuengling910
yuengling910's Avatar
Originally Posted by Blk003GT
i think i may have broken a ring landing and the debris may have been sucked into the valve and went over to the other cylinder before leaving the cylinders. bore scope tommarow its at the shop right now but more than likely problably new motor.
how did the debris get from one cylinder to another? maybe im missing something. i agree with oxford i think that you just detonated from having to lean a fuel mixture, and thats what damaged the plugs. best to let the shop check it out though, good luck.
yuengling910 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Sixer4Life
09-29-2015 07:03 PM
logan409
09-26-2015 07:43 PM
Quick Reply: did my untuned Supercharger just blow my motor?
