LCA+UCA installation/pinion angle???
OK, so i have definitely decided on the LCAs and UCAs to get, they are the adjustable ones from UPR. Has anyone else installed these?
http://www.uprproducts.com/shopping/shopexd.asp?id=2121
My concern here is about the "adjustable" part. How do i know where to set everything when i install them(im keeping it stock height for now)? Im worried that i will not set the pinion angle correctly and damage the rear-end. Can some one share some information about how the adjusting works?
when you remove one of the old arms, adjust the new one to the same length by lining up the holes in the bushings or use a mesuring tape, another thing is go buy two 5 or 6 inch bolts and stick them in each hole on the old arms and adjust the new arms intill they fit onto the bolts sticking thru the old control arms.
And if you're gettin adjustables and setting them to stock, then there is no point in the "adjustable" part. Just stick with the cheaper non-adjustable.
Yes but im planning on lowering the car later,...i dont want to buy CAs twice, so i figured i should get the good ones the first time around,...just my logic lol
