How much boost increase?
#31
#32
did you datalog that or are you just assuming that's what you saw at that?
If not, I'd like to know how you could watch the road, your tach, and the boost gauge all at the same time with 500+rwhp
Oh, and your not going to see 17psi. Your going to loose PSI due to heat from overspinning the blower.
#34
Boost is nothing but a measurement of restriction. Since different combos will show different amounts of boost even with the same blower using the same pulleys. It's really hard to say you'll make X amount of boost. With the na cams he'll limit himself.
The Novi is physically bigger than both. I do feel the Novi 2k is the best of the 3. Then the T-trim followed by the D1sc. The D1sc isn't much better than a S-trim and Si-trim will probably out perform it and is almost comparable to the T. The P1sc is really only good for 480 and down.
The YSI and F1A will make a lot more power than Novi 2K. But I still feel that the Novi 2K is probably the best all around SC for the 4.6. The T-trim isn't really much bigger tham the S-trim.
Novi 2000, procharger D1-sc and vortech T trim are all in the same class with the novi out performing the other two.
F1a and YSI are in a class together but the novi 2000 is in very close competitor.
Bottom line is to get a d1 or T trim to make same power as a novi 2000 you have to run alot more boost.
#35
To bad they weren't cheap 6 years ago.
#36
jwog666
12-27-2021 08:09 PM
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
10lbs, 34, boost, calculator, gt, increase, make, mustang, performance, power, psi, pulley, supercharger, trim, vortech
