What flywheel do I have? 2000 GT? 6 bolt or 8?
Old 05-14-2009, 02:31 AM
samsu402
samsu402's Avatar
Default What flywheel do I have? 2000 GT? 6 bolt or 8?
Does a 2000 GT with a T45 tranny have an 8 bolt or 6 bolt flywheel? How can I find out?
samsu402 is offline
Old 05-14-2009, 02:56 AM
devongarver
devongarver's Avatar
Smile
8 bolt, dont ask summit, they didnt know, i made a trip there for nothing. lol.
windsor motors(99-00) have 8 bolt.
romeos have 6 bolt
devongarver is offline
Old 05-14-2009, 06:27 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
My '01 VIN coded an 8 bolt (Winsor) and was a 6 once I got in there. This would seem to be consistant with your post, but originally replaced it on a Sunday, so had to re-install the original flywheel with new clutch. It was in good shape and have since replaced it with a billet flywheel when I did my T-56 swap.
Jazzer
Jazzer The Cat is offline
Old 05-14-2009, 11:59 AM
isjoining
isjoining's Avatar
8 bolt with 99-00 windsor motors.
isjoining is offline
Old 05-14-2009, 12:17 PM
samsu402
samsu402's Avatar
im real confused now. How can I tell whether I have a Windsor or Romeo?
samsu402 is offline
Old 05-14-2009, 01:28 PM
pcs
pcs's Avatar
your 8 vin #
x windsor 8 bolt 13 bolts on the valve cover
w romeo 6 bolt 11 bolts on the valve cover
you should have a windsor since it wasnt until mid 01 when they switched to the romeo.
pcs is offline
Old 05-14-2009, 03:13 PM
Jazzer The Cat
Retired Moderator
^ I wish I had known the valve cover bolt numbers prior to my clutch work couple years back, darn
Jazzer appreciates good info from his pepes
Old 05-14-2009, 06:50 PM
GT Tommy
GT Tommy's Avatar
Default Check this from American Muscle!
You may want to check out this American Muscle Website. When the website opens up, scroll down and click on Mustang Flywheels, then scroll down again to review your application. From what's posted, it appears that you have an 8 bolt hole pattern. However, you will never know what you will find until you remove the trans. Hope this helps. Good luck, Tommy.
http://images.google.com/imgres?imgu...%3Den%26sa%3DG
GT Tommy is offline
Old 05-15-2009, 01:52 AM
samsu402
samsu402's Avatar
So if the eighth number of the VIN is an "X" my motor is a Windsor?
samsu402 is offline
Old 05-15-2009, 02:45 AM
Sxynerd
Sxynerd's Avatar
99 & 00 are windsors and it's 8 bolt.. don't over think it.
Sxynerd is offline
Quick Reply: What flywheel do I have? 2000 GT? 6 bolt or 8?
