How much fuel pressure
Old 05-17-2009, 01:03 PM
jeff37110
jeff37110's Avatar
Default How much fuel pressure
How much fuel pressure should I be running at idle and how much at full throttle?
jeff37110 is offline
Old 05-17-2009, 01:43 PM
mustangman281
Banned
mustangman281's Avatar
29-30 at idle and 40-41 at wot.
mustangman281 is offline
Old 05-17-2009, 01:58 PM
GT Tommy
GT Tommy's Avatar
Default Here's what I found!
From viewing all the different GT Mustang forums, most people who own GT Mustangs report that their engines run best with their fuel pressure between 35 psi and 40 psi at idle. AllData has it between 35 psi and 70 psi as shown below. I assume they are talking about at idle and at wot. Good luck, Tommy.
GT Tommy is offline
Old 05-17-2009, 02:52 PM
mustangman281
Banned
Those are w/o vacuum reading not what he will see if looking at a fuel pressure gauge.
Old 05-17-2009, 03:30 PM
jeff37110
jeff37110's Avatar
So disconnect the vacuum and set it or adjust with vacuum on? Right now its reading about 32 with vacuum at idle and about 40 with vacuum wot. I have an adjustable BBk Regulator with a gauge built on it. If that helps anyone with info. Thanks
Old 05-17-2009, 05:03 PM
mustangman281
Banned
That is fine leave it alone. 40 w/o vacuum at idle is where it should be set.
Old 05-17-2009, 05:41 PM
jeff37110
jeff37110's Avatar
Thanks, appreciate it bro.
GimpyHSHS
19
12-19-2023 01:12 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: How much fuel pressure
