Weird idle after oil service yesterday...
Old 05-19-2009, 01:57 PM
tealfastback69
tealfastback69's Avatar
Default Weird idle after oil service yesterday...
Ever since i had my oil changed (yesterday) by somebody else my idle speed keeps changing within +/- 200 rpm when im stopped. And then when I put it in park the rpms go up to a higher idle than ever before. They must have messed with something so do you guys have any clue what they could have done? Is there any needle they could have adj when under the hood? Please help me out thanks.
tealfastback69 is offline
Old 05-19-2009, 02:52 PM
LynnBob Mustang
LynnBob Mustang's Avatar
Why would they mess with anything?
It is probably just a coincidence that something else went wrong or bad just after.
Lynn
LynnBob Mustang is offline
Old 05-19-2009, 04:55 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Did they disconnect the battery for any reason? This would reset the KAM and cause the PCM to have to relearn the idle air and long term fuel trims--among other things...
cliffyk is offline
Old 05-19-2009, 10:46 PM
tealfastback69
no the battery wasnt disconnected. i know its strange but in past experiences i have gotten jipped before...
are there any intake or air/fuel adjustments that could be changed with a screwdriver or anything on these cars?
Old 05-19-2009, 10:57 PM
black35th
black35th's Avatar
Sound like your Idle Air Controller (IAC) is starting to crap out. Probably just a coincidence that it happened right after the oil change. There's not really anything that they could have done to mess with the idle of the car.
black35th is offline
Old 05-19-2009, 10:58 PM
2000AZ5.0GT
2000AZ5.0GT's Avatar
nope, you need an electronic tuner to change anything like that
2000AZ5.0GT is offline
Old 05-20-2009, 05:36 AM
devongarver
devongarver's Avatar
+1 for bad IAC. i just replaced mine yesterday.
But take yours off and clean it with choke/carb cleaner first before you buy new. I cleaned mine and it worked but i had already ordered a new iac and it was in the mail the next day lol.
devongarver is offline
Old 05-20-2009, 06:07 AM
Sxynerd
Sxynerd's Avatar
it's "gypped" not "jipped". If you're going to use a racist word, at least have the courtesy to get it right.
Sxynerd is offline
Old 05-20-2009, 06:59 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Well before you go replacing parts, check the oil level... If its over-full by too much it will could cause a rough idle.
WhiteFoxGT is offline
Old 05-20-2009, 09:30 AM
tealfastback69
Thanks everybody, I'll check the IAC and oil level today.
Quick Reply: Weird idle after oil service yesterday...
