Clutch/Trans install?
i would recommend a tranny jack, even a cheap 35 dollar pos from ahrbor frieght, or at the very least rig up a platform to a floor jack. with the car on jackstands there isnt much room to hold the tranny with your knees, and its almost too high to hold on your chest, so i would def. setup something to support the tranny. Otherwise though, not too bad of an install really. I did it and im not a mechanic.
Yea its not a bad job... make sure before you put the new clutch in you get the flywheel turned at a machine shop...
Air tools and long extensions + swivel sockets are your best friend. You can wrestle the trans out by hand, or use an ATV jack (i just so happened to have one handy lol)
I find it easier to just have you and a buddy lift the trans in and out... so eat your wheaties.
And to get to the top bolts, you drop the trans crossmember, let the trans hang and use long extensions to get to the bolts.
with the trans crossmember out, the rear of the trans drops down enough to expose the top bolts.......long extension and swivel socket is still needed
