Comp cams XE274H ?
Old 05-27-2009, 12:59 PM
rman101
rman101's Avatar
Default Comp cams XE274H ?
So i found a killer deal (cams + springs for $400) and was wondering how these cams would be for a DD street car. install is nota problem i figured if they were worth it and had good driveability itd be a go.
i read some where that they would be no good on stock heads. in the future i was contemplating nitrous and i know the exhaust side is lower that hitech but would they work with the nitrous? and about how much power could i expect out of these?
car so far has - 4.10, diablo tune, 75mm tb/plenum, midpipes, catback, k&n filter
maybe i should skip these and go straight for the torque convertor and 100 shot.
rman101 is offline
Old 05-27-2009, 02:20 PM
PowerPonyPatrol
PowerPonyPatrol's Avatar
Wow were did you find those and springs for $400?? Everywhere I've seen the cams are around $599 alone, and the spring kit is usually $200 or so. Those are stage III cams, you would have to get a stall converter if you have auto. By themselves, you'd probably get around 30-40HP, but you'd be way better off if you got also got heads too since you're already in there changing cams. Adding heads would prob get you combined 80-100HP.
PowerPonyPatrol is offline
Old 05-27-2009, 02:46 PM
rman101
rman101's Avatar
found them on some local forums used.
heads are just a little out of my price rang right now though. with bolt ons except headers i could expect around 300 hp? these wouldnt be good for nitrous would they? and is there anything else i would need to look at getting if i did get these. its almost too good of a deal to pass up.
yes i have an auto and have looked at getting a 2800 stall convertor. because i found a good deal on that as well.
rman101 is offline
Old 05-28-2009, 05:33 PM
JayC
JayC's Avatar
Where did you get this BS? Those numbers are way off for adding heads.
JayC is offline
Old 05-28-2009, 06:07 PM
boduke0220
boduke0220's Avatar
you wont get the full effect of the cams if you dont have headers too.
boduke0220 is offline
Old 05-28-2009, 10:00 PM
ddmsgtr1
ddmsgtr1's Avatar
Aren't the 274s non-PI cams? I thought the stage 3 for PI's was an XE278.
ddmsgtr1 is offline
Old 05-29-2009, 07:20 AM
rman101
rman101's Avatar
they could be he had them on a 97 (i think) but i thought they might be interchangeable as the website didnt say anything about it. another question of mine i forgot to ask. and yes i know i wont without headers and heads. but one step at a time lol
rman101 is offline
Old 05-29-2009, 01:26 PM
Chris98Gt
Chris98Gt's Avatar
whats the cam card look like? whats max lift? if its around 500 then there npi cams and around 550 there pi cams, obviously if there the pi cams you'd need too look at the duration and lsa and check if they will clear the factory unnotched pistons.
Chris98Gt is offline
Old 05-29-2009, 01:52 PM
CAMDUP
CAMDUP's Avatar
XE274H = NPI
http://www.cushmanmotorsports.com/in...products_id=20
CAMDUP is offline
Old 05-29-2009, 09:28 PM
stangdriver2007
stangdriver2007's Avatar
all im gonna say is you better check your PTV clearance those are big cams. they are NPI cams because the lift on them is .500. the duration is long on them but dont say someone didnt warn you when your piston smacks a valve
stangdriver2007 is offline
Quick Reply: Comp cams XE274H ?
