Twin Turbo 4.6
Old 11-16-2003, 02:44 AM
redneck101
redneck101's Avatar
Default Twin Turbo 4.6
Too exotic for me, I say go all motor, no boost
redneck101 is offline
Old 11-16-2003, 02:53 PM
tripsevn7
Moderating with Angels
tripsevn7's Avatar
for about 3 grand less you could go with a cobra crank forged internals and the intercooled twin screw and be right there with that kit. plus your gonna need a whole new drivetrain for that kind of power</P>
tripsevn7 is offline
Old 11-16-2003, 03:00 PM
Jugador1
I ♥ Acer
Jugador1's Avatar
at what point would a new transmission be necessary</P>
Jugador1 is offline
Old 11-16-2003, 03:41 PM
Guest
Guest
Posts: n/a
My two centssays the engine isn't completely stock. You can't add 340 extra hp to a head that was built to flow for 260 hp. At some point you'll need turbo spec cams (there's two in the SOHC 4.6), new valves and springs at the very least. Eventually,you'll have spill back under WOT with the stock head.</P>
Looks like one awesome as hell setup though.</P><edited><editID>own3dbyyou</editID><editDate>37941.5710300926</editDate></edited>
Old 11-16-2003, 04:30 PM
USAMuscle
USAMuscle's Avatar
I think when they mention "600 rwhp on a stock 4.6 engine" they are speaking hypothetically, simply what is possible with their kit. Everybody in their right mind with a clue about Mustangs would know to use that much HP effectively would require extensive modifications to the engine and drivetrain, but if you can afford to dump $7,500 on a twin turbo kit, chances are you can afford the necessary modifications as well. Either way if you had the cash, it's a badass setup.</P>
USAMuscle is offline
Old 11-16-2003, 07:48 PM
2002 Stang GT
2002 Stang GT's Avatar
2002 Stang GT is offline
Old 11-17-2003, 10:00 AM
tripsevn7
tripsevn7's Avatar
T45 is only good for about 360 lbs of torque from what i am told, with 600 hp and torque numbers in that area you would need a world class or tko tranny. plus harnessing that kind of power with a 5 speed would be a hellified challenge. probably need a c4 or aode built up to actually utilize that kind of power.. i imagine you would need a new driveshaft and rear end too. the stock parts would probably twist under that kind of load
Old 11-18-2003, 05:28 AM
awwimer
awwimer's Avatar
that is a bullit intake on that 4.6. is it a bullit or just a upgraded intake?</P>
awwimer is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
TCStangerv6
10-11-2015 05:57 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
Quick Reply: Twin Turbo 4.6
