Tire size?????
Tire size?????
Have 2000 gt with 2003 svt cobra 17 inch whels. Car has sumitomo tires which suck. Tires are 245/45/17. Going to put on nitto 555r drag radials on back was thinking about 275/40/17 on back and 555s on front at 245/45/17. Any one have better input on size. car has bbk gripp inch and a half lowering springs with max motorsports caster camber plates. Can I run 275s all around. How will car handle? Any input greatly appreciated
correction, i would only recommend trying to fit 315's for 1/4 mile track use.. i dont wanna be the guy who gives you bad advice and in doing so you pop a bead off around a sharp turn.
275's are safe for DD or anything else... thats what came on those rims from the factory (all around)
Oops, my bad
I neglected to read closer and see the '03 Cobra wheels on there. In this case, I would recommend 255~265's. I think a 275 is a bit too large for a 9" wheel, but will fit. I think it has too much bulge and usually a bit sloppy in the corners.
If one ONLY wants the rear set for 1/4 mile track use, I would recommend going with a set of 15"s and the taller profile being allowed by such a wheel.
Jazzer
315 nitto 555r's work just fine on a 17x9 wheel.
I have that set up and it works perfectly. Nitto's are narrow as HELL. I had previously bought 275 555r's and they were BARELY any wider than my sumitomo 245's that i put on the front.
