2000 GT issues
Old 05-30-2009, 09:12 PM
crazy horse
crazy horse's Avatar
Default 2000 GT issues
It seems like there is always something wrong with my car, brakes, suspension noises, rattles, you name it. Towards the end of last year my check engine light came on and the codes showed all four O2 sensors were bad.
It seemed unlikely that this was the case but we couldn't find anything else so eventually replaced them all since it was around 75k anyway. The light stayed off for about a week and came back on with 5 codes, something about the sensor heater circuits and something else. It then went off and stayed off up until a few weeks ago, now there's only 2 codes.
Anyway, lately it seems like there's been a ticking. Last weekend it seemed to have gotten much louder and my rpm's would bounce between 500 and 1k sitting idle and will sometimes die shifting into gear. It's always had a problem occasionally when you shift it into gear the rpm's will go way down then rev up.
We took the passenger exhaust loose to get to the sensor, could this noise be an exhaust leak? Also any ideas what's causing those codes?
Thanks
crazy horse is offline
Old 05-30-2009, 10:21 PM
crazy horse
I sprayed out my iac with some fuel system cleaner. The rpm's seem more stable when putting it in reverse or drive, but I wasn't able to take it for a drive.
I think the noise may be the exhaust. It's pretty loud if you get down by the wheel well. Won't hurt to get under there and check it out tomorrow... assuming I can find a swivel to get up in there.
Old 05-31-2009, 03:28 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Thanks
What are the codes?
Look 'em up here...
cliffyk is offline
Old 05-31-2009, 05:08 PM
crazy horse
The codes are p0155 and p0161.
We tried cleaning the connectors and unhooking the computer and reseating it. I guess we'll try putting the old sensors back in those 2.
Old 06-02-2009, 10:24 PM
reznap
reznap's Avatar
Could be a bad ground causing what seems to be random problems. You can try checking your grounds and cleaning them up. Wishful thinking anyway.
reznap is offline
Old 06-03-2009, 06:51 AM
00' GT
00' GT's Avatar
i surely feel your pain! my 00' gt's startin to f@#k up alot too! i had a noise similiar to the one you described, it was a collector exhaust leak. another weird noise ended up bein the rt front hub bearing! and mine does tha rev up-down thing too! im bout to change the motor out along w/everything else so hopely that wiil help! lol!
00' GT is offline
Old 06-03-2009, 10:11 AM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
Thanks
You drive a F.O.R.D. Fix Or Repair Daily, get used to it.
ChalknCover is offline
Old 06-03-2009, 04:48 PM
boylanp
boylanp's Avatar
My '01 GT makes the noise too. '00 GT did the noise tend to go away as the engine warmed up? Or did it stay constant even after it warmed up? I thought that as the engine heated up it should seal up the leak, thats why I didn't think I had an exhaust leak, because the noise stays. Also my car does the rev up and down thing too, did anyone ever figure out what that was?
boylanp is offline
Old 06-03-2009, 08:51 PM
ct_white_stang
ct_white_stang's Avatar
Yeah, I vert makes all sorts of noises too and I am only at 32K. I just turn the radio up....guess that why I went with a loud exhaust.
ct_white_stang is offline
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Dathan
10-05-2015 05:52 AM
jc409
Convertible Tech
09-26-2015 08:28 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: 2000 GT issues
