Shift Kit & Tranny Fluid
just go with a mobil 1 atf i have been told that RP will ruin the clutches in the trans
i do not remember how many quarts i was thinking 7 but call the ford dealership
it will not take as much as the manual says because you do not drain the atf from the converter
Thanks 99 GT vert. I'll take your word on it & I'll go buy some mobile 1 ATF. I just wasn't sure with a auto which kind was the best. I don't want to ruin anythang. So thats why I started this thread.
If anyone else has any suggestions about AFT or does n don't with a shift kit please pm me or add to this thread. Thanks again everyone.
I'd look at this... Im not sure what you have man or auto so make sure first BUT check this out:
BTW: Ebay is a great place to look at as well.
(AOD '84-up) Transgo® Shift Kit® AOD-HP
Firm muscle car shifts; Hold 1st, 2nd, 3rd to any RPM. Wide Open 3-4 Shift; Holds 4th at high speed. Includes high rev kit ('80-early '83 use late '83-up Valve Body).
$103.99
(AODE & 4R70W '91-'04) Transgo® Shift Kit®AODE-3
Stick Shift; Competition, Off-Road, and Pro & Street. Full manual control.
$219.99
(AODE '91-'04) Transgo® Shift Kit® AODE-HD2
Short, firm, full-throttle shifts that have "class" performance. Back shift to any gear at your command. Holds the gear you select to any RPM. Has EPC relief to prevent hi-line parts breakage.
$104.99
$103.99
$219.99
$104.99
There are short shifters for manual transmissions if thats what you meant.
I'm imagining that's what he means. Everyone does that who has a manual, but shift kits are definately just for autos. Sorry pal.
I'm imagining that's what he means. Everyone does that who has a manual, but shift kits are definately just for autos. Sorry pal. Another reason why I love an auto. The shift kits are amazing for them.
