Brake Install Question
Old 06-02-2009, 09:05 PM
Veets44
Veets44's Avatar
Default Brake Install Question
I switched my front brakes today to the cobra 10th anniv. brakes and it went real well.
The only problem I am having is that when I put it back together, the fluid is leaking from the area that connects the hard line and the the stainless flex line.
I assume the line is flared, so could it be an issue there?
Veets44 is offline
Old 06-02-2009, 09:43 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
If you are leaking in that area, you need need new lines. This is a factory connection and would NOT attempt to repair/clamp it.
I recommend you pick up a set of SS braided ones for BOTH front/back and upgrade your fluid to DOT 4 or Super Blue. This is not expensive and will be VERY helpful if you find yourself at the track as I did. I had ZERO brake fade/heat soak issus with about 1.5 hours on track. Brakes were cookin' and felt great the whole time.
Jazzer
Jazzer The Cat is offline
JonnyBlazeGT
11-03-2015 01:10 AM
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
Fast-Hands
08-19-2015 06:54 AM
FD725
08-11-2015 03:43 AM
Quick Reply: Brake Install Question
