Throw out bearing?
Throw out bearing?
As soon as I push the clutch down, even just 1/4" I hear this whining/chattering noise. That's the throw out bearing going right? If so, is replacement of this relatively easy? What do I need to unbolt/take off in order to get the tranny off? Any comments are helpful. Thanks in advance.
Changing the Throw out bearing is a simple fix. The biggest issue is how to drop the transmission if you don't have a transmission jack. I'm going to change ours this week and I don't have a trans. jack. I'll just come up with a way to support it using jack stands and a floor jack. I'll let you know what worked for me.
First you will need to remove the shift know, boat around the lever, and lever. Then jack up car and remove exhaust and drive shaft. The manual says to just loosen and secure to side the mufflers and tail pipe, on cobra it says to remove it. I'll let you know when I'm done what I did. After removing exhaust, using a black marker, mark the position of the drive shaft bracket that is attached to the rear end. You need to make sure it goes back exactly how is was. Then remove the 4 bolts that hold the bracket to the rear end. Lower shaft and just pull it out the transmission. Then disconnect cables, sensors and connectors from transmission. Support the transmission first, then unbolt. Slide the transmission back to expose clutch. Now the manual does not tell you to how to lower the transmission while it is still attached to engine. I know on my vette, I could only lower it about an inch, then pull it back to clear the bearing. I'll let you know what happens on that also. Then unbolt the clutch release lever and remove bearing and lever. replace and put it all back together in reverse order.
Now that's basically what the shop manuals tell you what to do. I have not done it yet, but I'll let you know any issues that I have.
I have read to use the OEM bearing or TimKin. Good Luck to ya.
You also need to remove the starter. Do this after you remove the exhaust midpipe. Be prepared to catch transmission oil once you remove the driveshaft and began to lower the transmission. You may also want to consider changing your clutch and resurfacing the flywheel while you 're at it. You will need a swivel and extensions (18''-24'') for your ratchet wrench.
If the rear main seal is leaking, it would be a great time to change it. The TOB shouldn't be that bad a job if you have a decent set of tools. very few bolts to deal with if you are just going to change the TOB.
I'm about to pull transmission, The books don't talk about supporting engine. I've read a little about that here. On my 99 vette I had to support the rear of the engine. But it sounds like you need to support the front of the engine? confused
IIRC, on the Vette, the transmission IS the rear differential and not bolted directly to the engine. The transmission is directly bolted to the engine on the Mustang. Without the counter weight, the engine will rock forward.
