instructions: Removal of door panels
Hello
Just wondering if anyone knew how or where I could find the info to remove my door panels. I have side tweatz in the door panels that havn't been working since I've owned the car. It's been long enough and I wanted to take care of it. Thanks in advance.
there is a plastic push pin on the side closes to the door jam. remove that. Pull up the window switch panel/handle. Take off the connectors. look and see if you have any screws where the window switch were. remove. my driver didn't, passenger did. Remove door handle cover. Check for screws. I didn't have any on mine. Then just pull the door panel striaght up. You will have 4 screws holding you speaker in. Fairly easy.
there is a plastic push pin on the side closes to the door jam. remove that. Pull up the window switch panel/handle. Take off the connectors. look and see if you have any screws where the window switch were. remove. my driver didn't, passenger did. Remove door handle cover. Check for screws. I didn't have any on mine. Then just pull the door panel straight up. You will have 4 screws holding you speaker in. Fairly easy.
there will be 2 screws once you remove the lock/window switch cover, close to where youd grab to close the door.might have remove the little door lock plastic peice off. (mine look like 9mm hollow points bullets) then lift upward. On re install. start from the bottom, ive found that to be easier. All else sounds right tho.
