pi swap power loss???
Old 06-10-2009, 11:44 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
multiple misfires could bog you down quite noticeably
Check the COPs
WhiteFoxGT is offline
Old 06-10-2009, 12:40 PM
CAMDUP
CAMDUP's Avatar
Originally Posted by tylerdude17
if you go to that link that is exactly what my car looked like when i was done i put the crank at tdc and took off the timing cover and then took off the chains and re-timed it from there my car runs ok except for a couple of mis fires on 4 and 6 but the engine turnes over just fine there is no contact at all you would be able to feel it if it was hitting. do you think the misfires could cause that much trouble
uuhhhh......you NEVER said that you KNOW 2 cyls were misfiring
CAMDUP is offline
Old 06-10-2009, 12:44 PM
Repzard
Repzard's Avatar
Check the COPs
I agree with you.
My miss fire issue was lose cop's (wiggled too much on bolt that holds cop down)
Could also be a crank sensor or Maf ?
Repzard is offline
Old 06-10-2009, 12:49 PM
amoosenamedhank
amoosenamedhank's Avatar
If he did a PI swap he more than like doesn't have COP... unless he converted to that as well. Could be bad spark plug wires and or coil pack.
amoosenamedhank is offline
Old 06-10-2009, 01:11 PM
tylerdude17
tylerdude17's Avatar
ALRITE THANKS ALOT GUYS I WILL GET BACK TO YOU WHEN I FIGURE OUT THE MISFIRE AND WHAT IS COP anywase
tylerdude17 is offline
Old 06-10-2009, 02:02 PM
mustangman281
Banned
mustangman281's Avatar
Unplug the cam sensor and see how it runs.
mustangman281 is offline
Old 06-10-2009, 02:06 PM
masterofthepuppets99
masterofthepuppets99's Avatar
a COP is a coil on plug. since you did a pi swap then you should still have coil packs with wires coming from each pack going to each spark plug.
masterofthepuppets99 is offline
Old 06-10-2009, 02:08 PM
tylerdude17
OK I WILL AFTER WORK AND I DO STILL HAVE COP THEN NOW THAT I KNOW WHAT THAT MEANS
kawiguy827
09-22-2015 10:52 AM
2015Ecoboost
09-17-2015 01:48 PM
jaiidutch
09-14-2015 10:29 AM
Pyrate Dave
09-10-2015 07:30 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: pi swap power loss???
