Porting NPI heads
Porting NPI heads
Has anyone here ported there NPI heads? I am looking at doing a PI swap, but was also think about porting some NPI heads. Does anyone have any experience with ported NPI heads please chime in.
Porting the 4.6 heads SHOULD NOT BE DONE BY YOU.
Best advice, is to buy a set of used PI Heads and intake($400) and have them ported PROFESSIONALLY.
That will bring you to 300HP, and 315 Lbs Torque after tuning.
Unlike the 5.0 , the 4.6 will NOT RUN PROPERLY with uneven ports that are NOT PRECISE, and a tune will be needed either way you go for better performance.Hand porting a Computer Controlled 4.6 is highly unrecommended.
doing it yourself is a bad idea. However I well ported NPI head will flow just as well as a ported PI.
i don't know if i should believe this guy. i believe he is the same guy that was infamous in the 5.0 section for drilling into his crank because his flywheel didn't line up.....
You are correct each port needs to be as close to 100% the same just like the intake manifold does. The stock computer (with a tune or not) in both the fox bodies and later cars does not have a way to control fuel based on individual cylinders. So if one cylinder gets more or less air mass the computer never knows about it.
On our cars the computer assumes that everything past the MAF is the same. Doesn't matter if its a 5.0 push rod motor or a newer modular motor.
the bump in compression and porting will make a tremendous difference, compared to what you have now.
An aggressive 93 octane dyno tune will be nice, with the bump in compression, your going to have to stay 93 octane, the 4.6 is a ping master/
yea both are the true, but realize back then I was a teenager and that was my very first motor job.
