What TB/Plenum size?
Old 06-11-2009, 09:09 AM
DreamerGT
DreamerGT's Avatar
I did all my intake mods at the same time and the car pulled harder in the upper rpm's.
DreamerGT is offline
Old 06-11-2009, 12:55 PM
SilverGT03
SilverGT03's Avatar
Originally Posted by black35th
Yup the only complaint I've ever heard was about the TB, a couple people had to take a file to the hole where the throttle cable slips in.
Just a little heads up about LateModelResto, call them and make sure they have it in stock BEFORE you place the order online. I've tried to order numerous parts through them only to find out a week later that they are on backorder.
Thanks for the info, I'll keep that in mind before I do order
SilverGT03 is offline
Old 06-11-2009, 12:56 PM
SilverGT03
SilverGT03's Avatar
Double Post...
Old 06-11-2009, 03:29 PM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
I got the Accufab 75mm TB&P. I am happy with it, got it used, so can't complain. Plus if I go FI later on, im set. Biggest difference is in the throttle response.
ChalknCover is offline
Old 06-11-2009, 06:41 PM
Vovovovan
Vovovovan's Avatar
i'd go with 75mm. that's what i'm getting. also not sure about plenum, i think C&L looks pretty decent.
Vovovovan is offline
Old 06-12-2009, 02:14 AM
marcuslee842
marcuslee842's Avatar
I have the C&L and it works great. You also get a bonus sound when u smash the gas which make u passengers ask "What the hell is that swoosh noise"?
marcuslee842 is offline
Old 06-12-2009, 07:59 PM
ct_white_stang
ct_white_stang's Avatar
I have the Pro Products 75 tb and works great and was a good price for TB and Plenum.
ct_white_stang is offline
Old 06-12-2009, 09:54 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Read this...
In theory the 75mm TB is overkill and could reduce charge velocity, however empirically it probably doesn't matter.
FWIW I intentionally got a 70 mm TB--if I ever decide to go f/i I'll buy a 75 or the BBK 78 and sell the 70 for $60 on ebay for a whopping $30 "loss"...
cliffyk is offline
Old 06-13-2009, 11:07 AM
JoelT2855
JoelT2855's Avatar
I really like the Professional products plenum and throttle body.. no complaints for the money..
JoelT2855 is offline
Old 06-13-2009, 11:42 AM
Sxynerd
Sxynerd's Avatar
A stock long block w/ exhaust manifolds, o/r H, dronemaster, 75mm tb, and C&L plenum made 260rw in my car. With the addition of a V2, Innercooled and 10lbs at the manifold I made 440rw.
If it does decrease charge pressure and does hurt performance I would say that it's nominal. I'm sure anythings Better than stock but I don't believe there's much gained from the larger TB except just a few hp when the engine is still close to stock trim.
These engines need everything working together to produce good numbers. Any which way (but Loose) 70/75 or 78 it'll works itself out in the end, if you keep on modding your car.
Sxynerd is offline
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
10-01-2015 09:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: What TB/Plenum size?
