OEM or aftermarket Throw out bearing?
Old 06-15-2009, 06:12 PM
mrxr250rider
mrxr250rider's Avatar
Originally Posted by sv650lex
I just put in an aftermarket oem style. It made it three weeks before it was squeeking.
when your tob is bad it squeaks when you let out the clutch?
if so mines bad too
mrxr250rider is offline
Old 06-15-2009, 09:46 PM
Adam03GT
Adam03GT's Avatar
Mine is bad too
So are tehy even worth replacing if they just keep going bad? It wont hurt anything will it?
Adam03GT is offline
Old 06-16-2009, 10:17 AM
Ultimeas
Ultimeas's Avatar
I put in a spec stage 1. That TOB started squeking 2 weeks in. I've heard Spec TOB's do this though.
500th post ftmfw!
Ultimeas is offline
Old 06-16-2009, 10:21 AM
lizzyfan
Underboss
lizzyfan's Avatar
Try an aftermarket firewall adjustment/quadrant to take some of the cable slack/play up and your TOB should last longer
lizzyfan is offline
Old 06-16-2009, 10:34 AM
OzzDOA
OzzDOA's Avatar
The Timken bearing is the best one out there. It's not made out of plastic but Aramid, the same stuff bullet proof vests are now made from. The second best option is the FRPP heavy duty job.
OzzDOA is offline
Old 06-16-2009, 08:59 PM
kcp1989
kcp1989's Avatar
Default tob
I currently have a ford racing heavy duty tob and its held up so far after about 5k. I do have an aftermarket quadrant, and firewall adjuster so I think that has something to do with it. I had the same tob last time and it squeaked from day one.
I would go with the timken because thats what ive heard is the best at the moment. Alot of people on svtperformance are using them atleast.
kcp1989 is offline
Old 06-17-2009, 12:00 AM
ShinobiOfLegends
ShinobiOfLegends's Avatar
hmmm..... my girlfriends doesnt squeak with her current trans and it didnt with the stock one either.... and she has a FRPP hd tob. maybe some of ya'll just cant drive??
j/k
ShinobiOfLegends is offline
Old 06-17-2009, 01:22 PM
masterofthepuppets99
masterofthepuppets99's Avatar
yeah if your throw out bearing is squeaking then it will fail eventually. im not sure how long it will take, but it will get soooo loud and annoying too. jazzer had a really cool mod he did to his. he used a magnet from a hard drive to hold the clutch arm away from the pressure plate.
masterofthepuppets99 is offline
Old 06-17-2009, 07:56 PM
StockD15b
StockD15b's Avatar
my stock throw out bearing when i broke, it broke into two peices. still worked, just a lil stiffer.
StockD15b is offline
KingRando
10-02-2015 08:06 AM
winner99
10-01-2015 10:52 AM
Drastang
09-30-2015 03:48 AM
wraith777
09-28-2015 10:49 AM
09-24-2015 09:18 PM
Quick Reply: OEM or aftermarket Throw out bearing?
