OEM or aftermarket Throw out bearing?
Old 06-14-2009, 11:09 AM
luv2golf
luv2golf's Avatar
Default OEM or aftermarket Throw out bearing?
We have a 2000 GT that the previous owner put a stageII clutch. We just installed 3.73 gears a few days ago and the throw out bearing just went out. I don't know what brand of clutch was installed. Should I go with the OEM bearing or aftermarket? Some post say use TimKen. Do they make high performance TOB?
luv2golf is offline
Old 06-14-2009, 12:16 PM
vanquish
vanquish's Avatar
I need to change mine too and I hear that OEM is the best to go with.
vanquish is offline
Old 06-14-2009, 01:21 PM
Sxynerd
Sxynerd's Avatar
Go with "Metal" OEM. I just don't trust the new Timkin Plastic TOB's
Sxynerd is offline
Old 06-14-2009, 01:41 PM
J_Rod
J_Rod's Avatar
+1 oem throwout bearing
J_Rod is offline
Old 06-14-2009, 08:22 PM
StockD15b
StockD15b's Avatar
the TOB that came with my King Cobra Clutch took a dumb, replaced with a OEM TOB.. it took a crap... so beats me lol
StockD15b is offline
Old 06-14-2009, 08:52 PM
luv2golf
luv2golf's Avatar
Thanks guys, thats what I thought. Glad you all agree.
luv2golf is offline
Old 06-15-2009, 07:34 AM
Repzard
Repzard's Avatar
Stinking TOB , seems to be a common problem with not just Mustangs but quite a few Fords.
I have the same problem..TOB is a little noisy.( I guess its a cable adjustment, not enough slack and TOB ride on peasure plate fingers and spins and wears out TOB )
I hear quite a few people recommend the centerforce TOB over OEM .
Anyone have good luck with that one lasting.
I hear stay away from spec 2 TOB the same problem has happen as OEM.
Repzard is offline
Old 06-15-2009, 12:48 PM
945LSTANG
945LSTANG's Avatar
thats ford's dumb design....all of them are like that. no matter how much slack you were to give it, it will still ride on the pressure plate.
IIRC jazzer had some kind of mod that changed this...
945LSTANG is offline
Old 06-15-2009, 04:18 PM
sv650lex
sv650lex's Avatar
I just put in an aftermarket oem style. It made it three weeks before it was squeeking.
sv650lex is offline
Old 06-15-2009, 05:10 PM
StockD15b
StockD15b's Avatar
i think the t5's? have an steel input shaft sleeve available which is suppost to help reduce wear?
Quick Reply: OEM or aftermarket Throw out bearing?
