Fog Lights
Old 06-17-2009, 01:33 PM
MineralMustang23
MineralMustang23's Avatar
Default Fog Lights
New here with a quick question. Is there anyway to wire your headlights so that instead of the parking lights coming on with the fog lights just the fog lights come on? Any help would be great.
MineralMustang23 is offline
Old 06-17-2009, 03:40 PM
Obsequious1
Obsequious1's Avatar
You'd have to tie into the fog switch with a positive wire . Thats one way of doing it. Make sure the wire you tap into has no power when you turn off the car.
If it were me, I'd run a wire from the fuze block with a fuze link inbetween to the fog switch.
Obsequious1 is offline
Old 06-17-2009, 09:50 PM
Choppa
Choppa's Avatar
ha i jus did this mod 2 days ago and love it http://www.americanmuscle.com/indepe...ht-wiring.html thats wat i follwed jus connect the orange/purple wire from convertible top harness (ur coupe has this too) to the red/black wire coming from the switch BAM done
it takes longer to unscrew stuff then to do the mod itself
Choppa is offline
Old 06-18-2009, 03:22 PM
devongarver
devongarver's Avatar
i got all mine taken apart only to find i had no similar wires whatsoever, and proceeded to put it all back together and jumper out two terminals of replay number one in the engine bay instead. This simply allows me to have my fogs on with my headlights, not without the parking lights. You could seperate the two sets of lights via relays if you wanted. that would work well.
devongarver is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
12-08-2015 04:37 PM
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Fog Lights
