HELP! Can't get Trans. loose from Engine
2000, GT 5-speed. We are pulling transmission, we have all bolts out and everything taken off per OEM manuals. Be we can't get the transmission apart from engine. Is it just very hard to brake loose? Am I missing something that isn't in the manuals? The only thing we didn't do was drain the fluid. But I can't see how that would effect anything.
Help Please.
Help Please.
Help Please.
Help Please.
If you've not skipped any steps and you're just having trouble removing the bell housing from the block, you could tap around the seam with a putty knife lightly, I've done it on bigger stuff (trucks) and it works alright. Just be careful.
Not sure what you mean by mated, but I don't have to separate the bellhousing from trans. I've tried using a screwdriver and prying bellhousing from engine, and it seems stuck. Now I did have some problems getting drive shaft apart as well. Had to tap that with a hammer. I'm starting to think that this car was underwater? All the bolts seem to be rusted or just stuck together.
You have to be missing a bolt. Did you take those two out at the very bottom that hold the engine to transmission metal gasket? They go into the transmission, which threw me, but they have to come out. Took me an hour of pulling and prying to finally find it. It will separate easy once you have everything disconnected.
I got those. I didn't pull those till after I tried for awhile. didn't look like they did anything. But still transmission not moving. I'm bout to crawl under again and try a putty knife. I'll let you know something in a few.
I've seen the bellhousings and block sieze together. If your sure all the bolts are out try a come along around the tranny and rear axle to put pressure on it the start tapping with a hammer and prying a little also. Just be carefull not to break anything. also leave a couple bolts treaded in just a little so when the tranny pops loose it wont fall and break anything, including you.
They can be a bitch. I had to use a six foot bar to pop a silverado tranny apart once. I thought the tranny was going to break but it didn't.
good luck
good luck
Thanks guys. I've tried the putty knife for a while and gave up. going to soak the whole thing down with wd-40 and let set overnight. One question, where are the pins located. I don't see the location in the manuals.
Another question, the manual says there are 5 bolts holding the bellhousing to engine. 3 on one side and 2 on the starter side. Now in the manual they show pictures of the bellhousing under the disassembly section that has two holes at the very top of the bellhousing. Are there to bolts I'm missing? I can't see how you would get to them if there are any at the very top, but that would surprise me with Ford.
