catlitic converter question.
Old 06-26-2009, 01:23 AM
pcs
pcs's Avatar
like gun pig said, just buy one. very cheap and unless your muffler guy has a mandrel pipe bender, its not going to flow as well.
pcs is offline
Old 06-27-2009, 08:37 AM
ForbTheStang
ForbTheStang's Avatar
all right :update:
went to the guys house he had a lift, welder and a pipe bender the guys owns 13 mustangs and a 2008 GT 500 in the grage and a bad *** 95 cobra any ways we cut the cats off they ended up being hollowed out and i found out some outer things about the car the clutch has been replaced the rear drive shaft bolts were finger lose i about craped my pants they probley need to be replaced now found out that the rear diff was half full still cant figure out why it get so hot underneath the dash. checked for a hole but couldent find one. he bended the x pipe and welded it it sounds so much better now im gonna change the plugs this weekend.
ForbTheStang is offline
Old 06-27-2009, 08:49 AM
72MachOne99GT
2010 Blue Ball Award Recipient
72MachOne99GT's Avatar
Originally Posted by ForbTheStang
all right :update:
You sound like a relatively new car guy so I'm going to say this.
*in no mean degrading*
Make ABSOLUTELY 100% sure the motor is stone *** mother F-ing COLD when you take the plugs out.
We're talking about sitting overnight, or for several hours so that the cylinder head can cool off.
When putting the plugs back in, make sure they're gapped correctly, but most importantly, torque them to the correct specifications with a torque wrench. If you don't have one, buy one or borrow one from your friend with all the Stangs.
72MachOne99GT is offline
Old 06-27-2009, 01:44 PM
ForbTheStang
no im not a new car guy just new to domestic. yeah i know u can strip the head i will make sure that i leave it sit over night do u have to take the fule rail off? if not would it make it easyer?
Old 06-28-2009, 05:24 PM
pcs
pcs's Avatar
no, fuel rails can stay, just remove the cop's and that is it
pcs is offline
Old 06-28-2009, 05:25 PM
72MachOne99GT
Didn't want anyone to undergo a nasty head swap when it could have been prevented.
Nope, no need to take off the fuel rail.
Despite the fact that it looks like the plugs are at a CRAPPY angle, there is more than enough room to manuever once the COP's come off.
The only plug that isn't easy to get off is #4 back on the pass. side.
Even it comes off w/o too much fighting.
Old 06-28-2009, 06:45 PM
ForbTheStang
i took 1 plug out this morning and i guess it has bosh plat 4's on it i dono if i like them im probly gonna swap them out to NGk's
Old 06-29-2009, 02:17 PM
gunpig0313
gunpig0313's Avatar
I would run Autolite or Motorcraft platinum plugs the NGK are junk plugs most the time on Mustangs.
gunpig0313 is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
lovesilver
Members Mustangs
05-09-2019 09:18 PM
jerrytubes
10-23-2015 12:11 PM
guitarman376
09-30-2015 05:54 PM
Quick Reply: catlitic converter question.
