no fire
no fire
i changed my 1997 mustang npi heads to 01 pi heads and pi intake i put the car back togater goin by the book and its not geting fire to the crank sensor when moter is cranked its got electricity to the coils camshaft sensor & injectors but does not fluxuate when cranked i check the grounds also the thift light flashs when the keys in the on poison but then goes off. iv changed the crank sensor next i was goin to change the camshaft sensor ? i have a sct 3 tuner but the car does not read it when plugged in ? car ran find before i took it apart any help wood be great thanks
yea iv take it apart twice first time with rear stamp facing the rear no fire change it around busted a timing chain fix that with a new one and new oil turned it around i put it back togater just as the book sad to with the crankshaft sprockets bevel forward and the rear stamp on the trigger facing the rear i did take it apart the first time with the Harmonic Balancer at tdc then rolled the crank around twice with the heads off to the 6 aclock posipion safe mode lined the makes on the chain with the makes on the cam gears all with the battery unhooked. it turns over fine good compression
