18x10 275/40/18 too big?
I have an 02 GT and was wondering if 18x10 275/40/18 would be too big or rub in the front. What is the largest tire/rim or a recommendation that will not rub? The ones that I have (275/40/17 black bullitts) rub in front when turning hard and I am tired of it. I was thinking that maybe the extra inch would help with the rubbing, but I am not sure. I would almost trade for a nice set of stock bullitts at this point. As always, thanks in advance guys!
Whattup...This is my first post here...Just got myself a 96 GT "Cobra Clone"...I have 275/40/18 in rear and 245/40/18 up front. I'd call a local tires shop to see, but my guess would be yea they'll rub. I don't think the extra inch will help.
Don't post if you don't know what your talking about. OP you can run 315/35/18, or 315/35/17 and be fine no rubbing at all the 10" and 10.5" rims have the right offset to compensate for the wider tire.
So you're one of those huh?? An ******* for no reason...I love how people grow big ***** on a forum, and know everything btw...I wasn't looking for a comment on my post, just telling him what I have and what I'd do....And since you know everything, you didn't ask him if the car was lowered which would make a difference...So you should know what the **** you're talking about first bitch. My 245's in the rear rub the sidewall in steep driveways...FYI
Why must disagreement go this direction? And gunpig.... OP was asking about the front reguarding 10" wheel fitment.
OP, a 10" wheel will not run up front on an SN95 without some serious suspension mods or fender work. The widest 18" tire/wheel combo you can safely run w/o mods is going to be a 275/35/18" on your ride. Even this is likely to have a bit of contact on fender/liner, but easily addressed. You could probably squeeze some addtional tire up there, but a 265/35 is a better fit anyway, IMO.
Jazzer
Jazzer
According to americanmuscle they say that 275/35/18 is the biggest you can go w/out mods. I be willing to bet that they actaully test fitted them so I would trust them. All through when i put 315/35/17 (which they also said would fit) on my rearend i had a minor issue with my stock exhaust rubbing. goodluck
OP, I'm not quite sure I understand the logic you're going with here. Let me try to get this straight. You're having problems with a 275/40/17 tire rubbing up front, which I'm guessing is mounted on a 9" wheel, cuz that would be about proper for a 275. But you want to go with a wheel that's an inch taller, run a tire that's the same width as what you have now and has the same sidewall ratio (which I believe will make your tire taller than it is now), and to add to it, you want to run this on a 10" wide wheel on front? Don't take this too hard, I'm just trying to help, but if I've understood what you want to try correctly, I think you're going in the opposite direction of an answer. My guess is this will make your problem far worse than it already is.
