5.4 swap
Old 07-07-2009, 01:14 PM
  #21
liljojo4711
liljojo4711's Avatar
$695 isnt bad at all really. that and the engine will be the most expensive parts so thats good. im not going to do cams or anything, just new bearings, rods and pistons then im good to go correct. does it matter how many miles the engine has on it since im replacing some parts? will my odometer still read how many miles my 4.6 had or how does that work?
liljojo4711 is offline
Old 07-07-2009, 03:05 PM
  #22
amoosenamedhank
amoosenamedhank's Avatar
Well you might need to freshen up the block depend on the shape the cylinder walls are in. Personally I would look for a slightly lower mileage block or you might have more machine work costs.
I really think you should reconsider the cam though. It's not that much more and it will make a huge difference.
The odometer will read whatever the 4.6 was on and will not match engine miles... just the miles that are actually on the car.
amoosenamedhank is offline
Old 07-07-2009, 03:18 PM
  #23
ForbTheStang
ForbTheStang's Avatar
should i swap motors take the 5.4 out of my 06 f150 and put my 4.6 in the f150. im not gonna do it just a thouhgt thoe lol.
ForbTheStang is offline
Old 07-07-2009, 03:25 PM
  #24
amoosenamedhank
Well I think the 5.4 in your F-150 is a 3v... no? That would be more difficult... and you would have a slow as ***** truck.
Old 07-07-2009, 03:44 PM
  #25
liljojo4711
that would be a very very slow truck, plus u wouldnt be able to pull anything lol.
what set of cams would u recommend, how much are they and what else would i need to get the most out of them?
here is a list of what im pretty sure i need so far, please add, take away or make suggestions as far as brands and where do get them:
97-04 f150 or expedition block
HPS intake manifold
upgraded rods
upgraded pistons
upgraded bearings
all new gaskets
cobra brake system
upgraded fuel pump
ARP bolts
windage tray
timing cover
BBK 78mm intake combo
upgraded injectors
thanks for the help so far guys
Old 07-07-2009, 03:45 PM
  #26
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
you forgot the supercharger :P
99BlackPonyGT is offline
Old 07-07-2009, 04:02 PM
  #27
liljojo4711
im keeping it n/a for a long time
Old 07-07-2009, 04:12 PM
  #28
Sxynerd
Sxynerd's Avatar
Then what's the point?
Sxynerd is offline
Old 07-07-2009, 04:17 PM
  #29
amoosenamedhank
Personally I would start off with the complete 5.4 engine if possible.. that way you already have the timing components. You might need to buy new chains but eh no biggy. As far as cams go... Just get something with a decent mid range, you don't want to have to spin this thing to the moon. You're looking for a meaty power band(no homo).
Old 07-07-2009, 04:56 PM
  #30
liljojo4711
exactly, nothing special. if im going to have to do a swap i might as well gain some torque instead of spending the same money to put in another 4.6. thats the point...
Quick Reply: 5.4 swap
