noise when clutch pedal not depressed
Old 08-25-2009, 08:46 PM
89gtwith3.55s
89gtwith3.55s's Avatar
i had the same problem, and like everyone is saying its the throwout bearing... my problem was that i had a cheap clutch fork and it eventually wore away at the TO bearing... check it out... could be your input shaft too
89gtwith3.55s is offline
Old 08-31-2009, 08:27 PM
1FINE99
1FINE99's Avatar
I would guess the TO as well is chattering on the input shaft and you can grease it to make it quiet down but that is usually a temp fix since the grease will eventually go away and it'll come back. I had a similar prob. as well and polished up the shaft with emery cloth and it went away.
1FINE99 is offline
Thunderball
15
11-22-2015 11:49 PM
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: noise when clutch pedal not depressed
