problem with tb plenum install
ok i put on a dragon plenum and accufab TB i bought them from a guy so i did not recieve instuctions..
my car now when i rev comes down to about 1200rpm sits for a secound then drops to 750.. this never happend before i did it. does my idle just need to be adjusted down??
You may need to reset the throttle stop screw back to get the closed TB ait bleeed back to where the PCM can better control the idle--here's how to do that...
A slight hang at 1100 to 1200 rpm while rolling to a stop is normal, to insure adequate p/s pressure for the braking system.
if it flucuates then check for leaks or your iac. If it just chills at 1200 then down to 750 and stays then let cpu figure it out. But yes, always unplug batt for while to reset for tb/plen exchange. Unplug batt for 15/20 min then plug. Sometimes it takes couple days of driving to relearn.
Gary Ugarek
08-26-2015 08:41 AM
