removing nut on top of strut
Old 07-11-2009, 10:20 PM
ryanm
ryanm's Avatar
Default removing nut on top of strut
hey guys
just wondering how y'all remove the nut on top of the strut that holds bushings in place. Ive seen ppl say jam a large flat head in the top and then use an open ended wrench to remove the nut. didnt work for me. i dont have an impact wrench which was another suggestion. ive got new struts but cant get this nut off the old ones to switch out the hardware. any ideas? thnx
98 gt
ryanm is offline
Old 07-11-2009, 10:41 PM
99GTvert
is my username.
99GTvert's Avatar
I used the crowbar that comes with the spare/jack combo in the trunk as a screw driver to hold the top of the 'thing' in place so that it doesn't spin, then a buddy used an adjustable wrench to get the nut loose. It took quite a bit of force, but we got them off.
It helps to have two people for this.
99GTvert is offline
Old 07-11-2009, 11:57 PM
ridethemustanggt
ridethemustanggt's Avatar
removing the nut is a pain in the A$$. Ive done it a couple of times. Hit it with some penetrating oil, Find something large that will fit in the grove. I have a stripe of steel the fit in the worked perfect cause you could put it long ways. Be carfule not to strip the grove on top or to strip the nut. Ive had both happen, which resulting in the cutting off of the nut.
ridethemustanggt is offline
Old 07-12-2009, 02:21 AM
MustangMan00
MustangMan00's Avatar
we used a dremel tool to get off my friends. we just cut the nut off, cuz the new struts came with new nuts
MustangMan00 is offline
Old 07-12-2009, 02:55 AM
0hOneGT
0hOneGT's Avatar
Try loosening the nut with the car still on the ground using the jack crow bar, with the suspension loaded. Then it should be easier to use the jack crow bar, as others suggested, to loosen the nut one the front suspension is off the ground. Worked for me.
0hOneGT is offline
Old 07-12-2009, 10:35 PM
ryanm
ryanm's Avatar
Default got it
thanks for the tips. i broke down and bought an impact wrench and got it. tried the ideas
ryanm is offline
Old 07-13-2009, 09:48 PM
grogan
grogan's Avatar
NEVER try to undo the nut while the suspension is loaded..i did that and it shot the strut through the fenderwell. aswell as picked up the front of the car. didnt break nothing other than the fenderwell, and i think it damaged a wiper line cause my wipers wont spray now.
grogan is offline
Old 07-13-2009, 10:13 PM
GreenStallion
GreenStallion's Avatar
That my friend is a GREAT investment!!!!
GreenStallion is offline
67STANGX2
09-24-2015 12:29 PM
maestro1024
09-21-2015 02:40 PM
wawagner82
09-13-2015 09:02 AM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: removing nut on top of strut
