Pulleys and Cams
Yes, the pulleys are piggyback style. Their SUM-C2511 has SFI balancer is $160, but another $10-40 gets the brands recommended above. I think that all of the sets closer to the $100 mark will be the same. I wish they'd all verify that in their description/specs...some do. The set I received simply did not fit on the crank snout. Good luck with whatever set you decide to go with!
CMS stage 2.5 cams will clear just fine; hell even stage 3s don't require flycut pistons. So go with 2.5 cams. Don't buy them twice and if you are ever thinking going F/I but the 2.5 blower cams they will work na as well.
Well, I think that checking the clearance is good practice anyway, particularly if they are debatably close. It is promising to know that even the larger cams could work. I don't know if/when it will see any boost or spray. My limited research says the rods aren't super stout, but we see these glory builds on them all the time. More than anything, I just want to get this Mustang to be less of a slouch, and more of a "muscle car" or "sports car".
So in the mean time, what to do next...throttle body/plenum, MAF, gears? Gears will be the most noticeable gain I guess...that would expedite a programmer as well.
Have you actually measured these clearances? I found 0.005" with VT/CMS Stage 2 cams installed at a 108 intake centerline with a stock PI motor. With a cam gear advanced 2 degrees the valves would have been deep in the piston. The stock Ford gears are plus or minus 4 degrees BTW.
Combine that with the possibility of the stock cam gears being +4 to -4 degrees off, and it starts to look a little scary!
junior04
09-28-2015 10:53 AM
