Vacuum leak question?
Hi all. I had my clutch, pressure plate, and TOB replaced last week, and now I'm hearing a similar sound to the bad TOB sound I heard last week, if not the same sound.
My mechanic hears a vacuum leak, but as I hear it, the noise goes away when I push the clutch pedal all the way in. Could it really be a vacuum leak?
Thanks,
John
Thanks,
John
If you really believe the noise goes away when the clutch is depressed then you should goto another technician. He might be using "vacuum leak" to cover a possible mistake. Try another technician to get a second opinion.
Just got the car back - mechanic said he couldn't find any vacuum leaks, and that a little noise from the tranny is normal, since all the parts in it are spinning when the clutch is engaged (foot off pedal) in neutral.
Not sure how to proceed now?
-John
-John
