Drivers window out of adjustment
Old 07-15-2009, 07:40 AM
kodiak
kodiak's Avatar
Default Drivers window out of adjustment
When closing my ds door on my 2000 mustang gt window gets caught in upper weatherstrip and lays on top rather than on inside, mostly on the rear part of the glass. Is there a way to adjust this? Any help greatly appreciated
kodiak is offline
Old 07-15-2009, 08:40 AM
jjandascog
jjandascog's Avatar
Ahhh, sounds like you glass has come out of the window channel a common problem. There are several ways to fix it, some just glue it back in but it will come unglued again. I fixed mine by replacing the rivet that holds the channel to the regulator that way it will not kick the glass loose again. I have some pictures let me see if I can find them.
If you take you door panel off you will see where it slipped out and why this is causing the window to roll up to far and lay on top of the seal
jjandascog is offline
Old 07-15-2009, 11:35 AM
kodiak
kodiak's Avatar
Default window adjustment
I just did exactly what you said. Thank you and if find those pics I would love to see them to see if I really did the right thing
kodiak is offline
b8checker
09-30-2015 07:11 AM
DreadPirateRoberts
09-26-2015 02:11 PM
col2560
09-25-2015 06:51 AM
lincolnshibuya
09-24-2015 10:46 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Drivers window out of adjustment
