So if it isn't the PCV valve, what is it?
So if I just replace the hose it should be fine? I tried replacing with a different hose from advance auto but it still clamped shut. Possibly still too soft? I think I'm going to call the dealer and see if they might have a new hose in stock to replace to see if that might be the case. Hopefully because that would be a great, easy fix.
Ok so I ended up replacing the entire part (16.85 at the dealer). When I got the part, it didn't completely match the one I had but I still got it to work. So far the car runs fine. I need to clear the code and see if it comes back on again but we'll see. For those of you who are interested, here is the part number:
F6ZZ6C324CA
F6ZZ6C324CA
