PI-heads+blower on stock bottome end??
Old 07-26-2009, 05:03 PM
toolegit86
toolegit86's Avatar
Default PI-heads+blower on stock bottome end??
Is it a good idea?? i am getting a stock bottom end while i build a stroker on the side.
i have a new set of pi heads and a 96 4/6 sohc bottom end. and a vortech supercharger running 10psi ithink it might be more. will it take it? or is it all in the tune?
toolegit86 is offline
Old 07-26-2009, 05:09 PM
Chris98Gt
Chris98Gt's Avatar
I'd run it at 8psi, that's what I'm running and I'm right around the 400 hp mark on 93 with 11* total timing, with an air to air intercooler.
Chris98Gt is offline
Old 07-26-2009, 05:15 PM
toolegit86
toolegit86's Avatar
I thinkin of tryin it on 10psi and just seein what happens
Old 07-26-2009, 05:37 PM
Chris98Gt
Chris98Gt's Avatar
why ask for advice if you weren't planning on listening?
Old 07-26-2009, 06:50 PM
toolegit86
toolegit86's Avatar
i was just seeing if some one has done it and had a anything good to say about it. the bottom end has 117k miles on it and i know it will not last but its worth a shot. your specs are something for me to shoot for and i thank you for that.
Old 07-28-2009, 08:12 PM
silentshredr
silentshredr's Avatar
i just did the swap myself, v2 running 10 lbs. and did the pi swap on a non pi engine. I installed cometic 0.75 head gaskets to keep the compression ratio near stock.
silentshredr is offline
Old 07-29-2009, 12:38 AM
toolegit86
toolegit86's Avatar
let me know how that works for you. i think i am going to save my pi heads for my forged block. as of right now i am going to put a stock motor on 10psi and run it for a while.
2007CalSpec
12-13-2020 11:42 AM
Dragonus18
09-09-2015 01:21 AM
TimeLord101
09-04-2015 09:27 AM
Luke9222
09-04-2015 06:46 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: PI-heads+blower on stock bottome end??
